"Converter" vs "Controller"?
johnyradio
Joined Oct 26, 2012
615
I'm looking at DC-DC IC's, and trying to understand the difference between a "converter" and "controller".
Would it be correct to say that a controller is simply a PWM, which requires more external electronics to be a full-fledged converter, while a "converter" IC integrates feedback and other electronics, including maybe even a power mosfet, into the IC to make a complete converter?
Would it also be correct to say that an original design with a controller and more discreet parts could be a lower BOM cost than a converter chip, but larger design effort?
Here's a controller
https://www.ti.com/lit/ds/symlink/lm3488.pdf
Here's a converter
https://www.ti.com/lit/ds/symlink/lm5157.pdf
28,576
Caution is needed in assigning classifications because different folks use different meanings for words. Some do it because they have no clue, others do it to confuse, and a few just speak a different language. AND , Ian0 is also correct.
Papabravo
Joined Feb 24, 2006
22,116
Many components that used to be available in quantity one(1) from retail outlets are now unobtainable without a volume order. You literally cannot do what people used to be able to do for education and enjoyment.
johnyradio
Joined Oct 26, 2012
615
Is that related specifically to my question about controllers and converters? Or just generally to all components?
Papabravo
Joined Feb 24, 2006
22,116
It is particularly related to power supplies of all descriptions, since that used to be the de facto first project for most electronic enthusiasts. Since you mentioned the relationship of discrete parts to BOM cost I thought you were considering a decision on which way to go.
