conversion of netlist to schematic
yo_c66
Joined Dec 6, 2024
hi, is there something that converts netlist into a graphical from or something similar?
i know about falsted simulator https://www.falstad.com/circuit/, but unfortunately, its import and export format is different,
and the challenge lies in the coordinates, since the falsted sim has the input as following:
$ 1 0.000005 14.235633750745258 55 5 50 5e-11
v 176 256 176 80 0 1 40 5 0 0 0.5
r 176 80 336 80 0 180
c 336 80 336 256 4 0.000032999999999999996 1.3535464127928016 0.001 0
w 176 256 336 256 0
o 2 64 0 4099 5 0.05 0 2 2 3
38 2 F1 0 0.000001 0.000101 -1 Capacitance
while netlist for this would be :
* Netlist for RC Circuit
V1 1 0 SIN(0 5 40) AC 1 ; AC Voltage Source with specs for both TRAN and AC analysis
R1 1 2 180 ; Resistor: Node 1 to 2, 180 Ohms
C1 2 0 33u ; Capacitor: Node 2 to 0, 33 microFarads
so the problem here if someone would want to convert it is getting the coordinates correct for the circuit
yo_c66
Joined Dec 6, 2024
hey, I think i didn't deliver exactly what I was looking for, so basically for any circuit generating a netlist should be pretty easy right
so what I want is something that converts the netlist into a graphical format for simulation tools, so that instead of getting simulation results from the netlist, the user can interact with the circuit and edit it if he wishes
yo_c66
Joined Dec 6, 2024
LT Spice, as above in post #2.
Sorry i didn't understand
Does LT Spice have the ability to convert netlist?
If so can you please guide on how it works
I want to convert netlist into a graphical circuit schematics meaning i want to visualise the circuit from a netlist
Not generate a netlist from schematics(i know how to do this already)
WBahn
Joined Mar 31, 2012
33,239
I don't know what's out there now, but I've seen tools demoed/pushed that do this -- now, whether they did it well is a matter of debate.
The problem is similar to using a tool to do automatic place and route of a PCB from a netlist. The place-and-route tool has no idea what is or isn't important, beyond whatever annotations might be contained in the netlist. So the result is usually, at best, a rather poor starting point. I always found it much faster to ignore that those tools exist and do it myself, because I had a much more complete grasp of the higher-level layout goals in mind and so I could focus on the important things first and then shoe-horn in the other stuff around it.
In many ways, creating a useful schematic from a netlist is actually harder, because there are at least good generic metrics for gaging a PCB layout that the tool can try to maximum. But a schematic is much more about conveying information to a human and good schematic layouts reflect higher-level functional organization and signal flow conventions that are very difficult for a tool to infer from a netlist. So, more than a PCB, you can expect an autogenerated schematic to require a significant amount of rework before it is useful.
ericgibbs
Joined Jan 29, 2010
21,583
hi yo,
This is the netlist text in LTSpice that creates/draws a potentiometer.
E
* This is the potentiometer
* _____
* 1--|_____|--2
* 3
.SUBCKT potentiometer 1 2 3
.param w=limit(wiper,1m,.999)
R0 1 3 {Rtot*(1-w)}
R1 3 2 {Rtot*(w)}
.ENDS
