controller with three usb port
alimash
Joined Oct 12, 2016
67
hello guys
i am looking for a controller that include three USB ports
i am using USB 3.0 so the data rate must be in gigabytes/s
i was told that only ARM processors support this kind of work but the problem is that i do not have the required tools to implement such device so if there was any development board that i can buy,kindly guide me
thank you
kubeek
Joined Sep 20, 2005
5,796
So you want three USB 3.0 ports on a microcontroller? I doubt you can find such, you would need some large full fledged processor that either has these or has a PCIe bus.
alimash
Joined Oct 12, 2016
67
what about an external usb 3.0 driver?
i can connect it to the processor
kubeek
Joined Sep 20, 2005
5,796
If you want to connect three devices and in total they require more than 625MB/s, then you cannot use a USB hub and a single USB port on the CPU and you need to use a USB port for each device. Tell us more abouth what devices do you need to connect.
alimash
Joined Oct 12, 2016
67
hello friend
i want to connect two computers and one usb 3.0 flash drive
one computer will be able to read and write and the second is read only
i said three USB ports earlier because i would like to use the usb ports of the pcs
but any other suggestion is very welcome
thank you
