controlled current source
IMG_2894.jpegRegarding cap discharging, here the path is shown. The cap is discharged through p-ch mosfet. The current is limited by Rds of this mosfet that is usually around 10ohm for small signal mosfets. So the initial peak current is about 3V/100=300mA, usually much less since the mosfet isn’t turned on in zero time (in linear region at beginning). Also 100mA countinous current mosfets is able to peak 500mA without any problem.
