Control Voltage of DC Motor
Bernard
Joined Aug 7, 2008
5,784
This old draDrawr 00000.png wer opener may not match your system, but what we want is a lead common only to down, like lead
from motor + to lower relay contact, toward ground. Insert 1 or more diodes rated for motor current in this lead. About .7 V drop / diode.
Just drop thumbnail any old place?
animartis
Joined Sep 12, 2016
7
Thanks all for the advice. After careful consideration and all the advice, I opted to extend the piece of metal that presses against the lever switch. With a 6" piece, I was able to consistently trigger the switch and not go past it. Thanks!!!
Kjeldgaard
Joined Apr 7, 2016
476
I do not think we have seen a schematic, of the current motor control.
But what about using the make contact in the lower micro switch, to actively brake the motor?
It's the same way most wiper motors use to park the wipers at the bottom of the wind shield.
38,631
Adding suppression diodes across the relay contacts should greatly damp the overrun of the motor when the power is removed.
You should have those diodes anyway to protect the relay contacts from the motor inductive spike.
If you post a diagram of your connections I can tell you where to put them.
Try using a smaller spool drum it will slow down the travel and lower the holding torque. Another trick though more complicated adding a timing relay to momentary reverse the polarity acting as a brake.
BillB3857
Joined Feb 28, 2009
2,573
Gravity will tend to extend the coast time of the motor in the down direction. Looks like you could use dynamic braking. The thread here... http://forum.allaboutcircuits.com/threads/12v-go-cart-forward-reverse-switch.94178/#post-693690 talks about controlling a go-cart, but the theory is the same. Post 13 talks about dynamic braking and post 15 give a link that includes a very well used circuit that has, as a side benefit, dynamic braking.
As a mechanical solution, could you install a positive stop that would engage just beyond the point that your down limit is actuated?
