Control Voltage of DC Motor
animartis
Joined Sep 12, 2016
7
Hello everyone,
I have a cabinet that raises and lowers with the use of a windshield wiper motor and a cable attached to the top. I have limit switches to stop the movement in both directions, but the problem is that it travels so fast when going down that it often will blast right by the bottom limit switch. I not not very circuit literate, but was hoping there was a way to limit the voltage on the down swing so the cabinet didn't travel so fast and would be stopped by the limit switch. For example, instead of providing 12V to the motor, I want to reduce it to, say, 9V. Any advice would be GREATLY appreciated!
Here is an example of it in action.
Thanks!
18,133
Move the switch? Change the gear ratio to slow it down? Reducing the voltage might help, but you may want to test that before you commit to that strategy.
22,102
If you have less current in the down direction, there will be less torque. Less torque means less acceleration, and thus lower velocity. Depending on the mass involved I could see running the motor in the up direction with so little torque that the cabinet falls gently in the down direction.
animartis
Joined Sep 12, 2016
7
All great responses and suggestions, thank you. The problem is not that it stops too low, but completely go past the limit switch and the motor keeps running. I've attached some pictures that might help clarify. I am using a two channel wireless relay and believe that if I can reduce the voltage on one side, it should move slow enough to engage the limit switch without going past it. The power supply is a 12V motorcycle battery. As you can see in the pictures, there is just a single spool and no gearing. I could swap that out for a smaller spool but that would impact have fast it goes up, which I don't want. The last picture shows how I engage the existing lower limit switch.
22,102
You still don't get it. Speed depends on torque and torque depends on current -- NOT VOLTAGE!!
You want to restrict the current when moving down to a value that lets the cabinet descend at an appropriate speed. When you hit the limit switch you want to reverse the motor to decelerate the cabinet for a smooth landing.
animartis
Joined Sep 12, 2016
7
That's why I said that I was circuit illiterate in my initial post. So maybe a better question is, "How do I reduce the CURRENT in my existing design?" Your suggestion doesn't make any sense to me. The torque and current when the cabinet is going up is fine because it is under a load. Its just when its not under a load that it goes too fast.
animartis
Joined Sep 12, 2016
7
Hi ramancini8, I have not, but it is a good suggestion. I fear that weight of the cabinet is too great and it would travel even faster if I were to uncouple the motor. I truly believe that figuring out a way of slowing down the motor in the downward direction would meet my needs, I just don't know how to do it. Would a potentiometer work?
30,771
The problem is not that it stops too low, but completely go past the limit switch and the motor keeps running. The last picture shows how I engage the existing lower limit switch.
You can't move the switch up?
Can you lower the voltage to a value that still raises it?
animartis
Joined Sep 12, 2016
7
Hi Max (love the name), the problem is not the location of the lower limit switch, but the fact that cabinet is moving so fast that it engages/disengages the switch as it presses it then goes past it. That's why I'm thinking that reducing the current is the right place to start. Do you think something like a rheostat on one leg of the circuit would work?
30,771
As I mentioned I would first look at detecting what the minimum voltage you can go with and achieve both raise and lower as a possibility.
You reduce the voltage to reduce the rpm on a DC motor.
18,133
Maybe use a block of wood instead of the metal bar. The wood could extend farther up so that the switch stays engaged. Maybe you don't have the room for an extended piece of wood when the car is at the top of its travel?
cmartinez
Joined Jan 17, 2007
8,828
I was about to suggest exactly the same thing. Design the lever activating the limit switch in such a way that it always engages the switch, even after it goes past it. And then maybe move the switch a bit up, until you get the desired stopping height.
22,102
Google "Voltage Controlled Current Source". Using this concept you can adjust the current to a value that just holds the load in place. Now decrease the current a little bit and the load will start to descend. We had exactly the same problem with early hard drives. In to out seek times were consistent when laying flat on the table. When the drive was placed on it's side the garvity assist made the in to out seek time much less than we expected.
animartis
Joined Sep 12, 2016
7
You are correct, there is limited space on all sides of the cabinet, as well as the top and the bottom.
