I'm working on an energy harvesting circuit known as an in-house harvesting circuit (cc-ih) and would appreciate some guidance on implementing it in Simscape within Simulink.
Circuit Description: The circuit is designed to harvest energy using the following key components and process:
- AC Source and Rectifier: An AC voltage source feeds into a full-wave bridge rectifier consisting of four diodes. This setup converts the AC input into a DC output.
- Capacitor Charging: The rectified voltage charges a capacitor, which stores the harvested energy.
- Voltage Monitoring: A voltage sensor monitors the voltage across the capacitor.
- Control Logic with MOSFET Switching:
- The control logic monitors the capacitor voltage.
- Once the voltage reaches a threshold of 2.4V, a MOSFET is triggered to connect, allowing the capacitor to discharge through a resistor (acting as a load).
- The MOSFET is turned off when the voltage falls below the threshold, allowing the capacitor to recharge.
