Contradictory equations in BJT
Fethi
Joined Nov 23, 2017
2
I have a problems with equations in bjt.Let me explain with an example :
Circuit
It is clear that the base current depends on RB by mesh analysis :
Mesh-analysis
However if we think about the collector current formula which is Ic = Is . e^(Vbe/Vt)
In this formula Is, Vbe and Vt are constant.(at least for ideal bjt).So collector current is constant.Then , base current is constant(Ic=β.Ib).Finally emitter current is also constant because it is sum of base and collector current.As a result, there is no importance of resistance in circuit for currents.Because currents are already determined by formula.I know this is not true but I couldn’t find an explanation.Can you help me?
Thank you,
(Moderator's note: In the future please embed images in you post rather than linking to off-site material.)
hobbyist
Joined Aug 10, 2008
892
The transistor is considered a current source, according to the equation, therefor the resistor RC is not used to limit collector current, but rather used to develop a voltage across it with respect to the voltage across the transistor.
The transistor and RC form a variable voltage divider.
38,540
Vt is constant but Vbe is not constant.
It depends upon the base current which is determined by Rb.
The base emitter voltage is basically a forward diode drop as given by this equation where I is the base current and V is Vbe:
