I have a problems with equations in bjt.Let me explain with an example :
Circuit
It is clear that the base current depends on RB by mesh analysis :
Mesh-analysis
However if we think about the collector current formula which is Ic = Is . e^(Vbe/Vt)
In this formula Is, Vbe and Vt are constant.(at least for ideal bjt).So collector current is constant.Then , base current is constant(Ic=β.Ib).Finally emitter current is also constant because it is sum of base and collector current.As a result, there is no importance of resistance in circuit for currents.Because currents are already determined by formula.I know this is not true but I couldn’t find an explanation.Can you help me?
Thank you,
(Moderator's note: In the future please embed images in you post rather than linking to off-site material.)
Circuit
Mesh-analysis
Thank you,
