continuity check after mosfet
mwawrzyniec
Joined May 7, 2014
13
ghThis is a simple example of what I am trying to do and the problem that I am trying to overcome:
This is arduino based, attached is an 8 bit shift controller, each out pin of the shift controller is running to a mosfet working as a power switch for 8 jindividual LED's.
What I am trying to do is a continuity test to check and see if there is an LED properly connected without supplying enough power to noticeably light up the LED.
#12
Sounds like testing the igniter on a model rocket. Try sending 100 ua through the LED and measure the resulting voltage across the LED.
18,183
I would argue that a "function" test requires producing light, as that is the basic function of an LED. But otherwise the proposed test, to look for a Vf when a small current is passed, makes sense. I suppose you could refine the test to require the Vf to be within an acceptable window.
#12
A bit less than that. If you have a white LED that needs 3.2 volts to light up, the resistor would be 18k to get 100 ua with the remaining 1.8 volts.
Of course, I'm assuming that LEDs break over like a well behaved zener diode would.
mwawrzyniec
Joined May 7, 2014
13
So here is what I came up with, please keep in mind this is my first electronics project. I omitted the connection to my shift registers. They will be connected to my arduino. I am attempting to build a launch controller for fireworks. The panel will be fitted with LED's for now so I can function test my circuit. The 9v will power the Talon ignighters (http://www.pyrouniverse.com/forum/showthread.php/32881-Talon-firing-current-data) when 5V+ARDUINO_1 is supplying 5V, alternatively when 5V+ARDUINO_2 is supplying 5V, the 74HC165N will be able to store the individual continuity checks.
Will the 74HC165N will be burnt out during normal operation?
View attachment controller.sch
#12
So, the question is: If I apply 9 volts to the data input of a 74HC165 that has a supply voltage of 5 volts, will it hurt the chip?
I think the answer is "yes".
The 74HC inputs have diode protection and they will burn out.
Their normal input current is 1 microamp.
The RCA book I'm looking at says the RCA QMOS devices have a 20 ma current limit, but I have no way of knowing if you're using RCA brand QMOS chips of if this book from 1989 is still the standard for these chips.
Simple answer? Don't over-volt the inputs.
Are the LEDs the square boxes right of center?
mwawrzyniec
Joined May 7, 2014
13
The square boxes are 2 pole terminals that will have LED's in them for testing. If I put a resistor after the terminals will this solve my issue or is there a better way to handle this?
#12
A resistor won't fix it. The simple way is don't apply excess voltage to the inputs.
Besides this, I think you have missed several ideas. First, LEDs need a current limiting resistor or they will burn up. Second, the LEDs need a current path to ground and you didn't provide it. Third, LEDs are the most reliable light devices ever invented. Why do you want to test LEDs? To see if they are plugged in?
mwawrzyniec
Joined May 7, 2014
13
The LEDs are there to test the circuit during beta testing. The 2 pole terminals are there to connect Talon clips. I am using the LED's because the talon clips are burned up during use. When I put an LED into the terminals I will attach a resistor to them. My goal is to be able to test if they are plugged in. Is there a better way to do this?
mwawrzyniec
Joined May 7, 2014
13
I added a diode to each line, attached a common ground with a resistor after. I also added a MOSFET to the ground controlled by the same power source as the MOSFET that controls the 9V power. I believe this may solve my issue.
#12
Here's an idea. Add a resistor to limit the current to 100 ua, provide a limiting zener diode so you don't blow up the chip, and measure the results. If the input is high, the LED is connected and current is flowing. If the input is low, the LED is not working.
ps, that's a 4.7 volt zener diode but it's hard to read with all those dots on the page.
There are a lot of ways to do this. Yours might work just fine.
mwawrzyniec
Joined May 7, 2014
13
I was having some trouble to get this circuit to work, I have attached a schematic of the basic for my initial function test. The shift register is being controlled by an arduino. I measured the gave at 5v. When I run my code, i get LEDs placed in the terminals to light up, however when I switch them out to my talon clips they are not working. I measured the voltage after the mosfet "IRLB8743PBF" and got 1v. The mosfet should be fully saturated with the 5v at the gate? Does anyone have any suggestions?
Thanks in advance,
ronv
Joined Nov 12, 2008
3,770
Your fet is set up as a source follower instead of a switch, so the source will be a threshold voltage lower than the gate. Move the load to the drain side.
