Consolidating two 2732s into one 2764 (solved)
metermannd
Joined Oct 25, 2020
472
So I have a circuit currently fitted with two 2732s and which I'd like to swap for a single 2764... but I'm having a bit of a brain block correlating the control lines for the 2732 to those for the 2764.
What am I not seeing?
35,112
2764 has the following pins:
Pin Name
2 = A12
20 = /CE
22 = /OE
2732
18 = /CE
20 = /OE
Connect A12 to 2764 pin-2
Connect GND to 2764 pin-20
Connect N1 to 2764 pin-22
metermannd
Joined Oct 25, 2020
472
I laid out and sent in an order for a small adapter board (it plugged into where U4 would reside on the board) and it worked! Thank you!
