Consider a circuit with DC voltage source of 8V, a diode, and a resistor of 2.2KΩ are connected in series. The voltage drop across the resistor is *
nikhil027
Joined May 15, 2021
7.3 V
7 V
6.9 V
6.5V
Papabravo
Joined Feb 24, 2006
22,073
As this sounds like homework, why don't you tell us what you think the answer is and what evidence you have to support that conclusion.
BTW - does it mention the type of diode? It could be silicon, or Schottky, or germanium, or zener, or LED. The answer to your question kind of depends on the answer to my question.
strantor
Joined Oct 3, 2010
6,875
Is that a word for word copy of an assignment question or a halfass "my time is too important to waste on transposing every detail" summary of an assignment question? If that's the whole question then it's a halfass question and deserves no more than a halfass answer.
"A diode"? Fwd biased or reverse? What kind of diode? What's it's voltage drop?
Answer = 8V - diode voltage drop (which isn't given).
Papabravo
Joined Feb 24, 2006
22,073
And I thought I was being snarky tonight. A tip o' the hat to you sir.
Oh! One more thing. I forgot to ask if the voltage source has any source resistance. That'll make only a small difference in any case.
Teyvanai
Joined Dec 6, 2015
24
Sir this will totally depend upon the maximum current taken by the resister and Diode together
once you do know off this then [[ apply Ohms law with the 2.2K ohm resistor to get the voltage drop across the resistor
34,716
If you know the current then you apply Ohm's Law.
If you know the voltage then the answer is simple math.
You don't know the current or the voltage.
Take it up with your instructor.
Audioguru again
Joined Oct 21, 2019
6,826
Isn't this a "select one of the four following voltages" question?
Since the resistor has a voltage across it then the diode must be forward biased.
Then lookup the forward voltage of diodes and use simple subtraction to find the correct answer.
34,716
Since you are given four answers to choose from and you were not told the type of diode, pick a device with the following forward voltage at 3mA diode forward current:
(a) 0.7V
(b) 1.0V
(c) 1.1V
(d) 1.5V
