Connectors for 30awg wire?
Keith Pritchard
Joined Oct 15, 2020
7
I need to find some JST or similar, 2 pin, wire-wire, non permanent connectors (with or without wires already fitted), for 30awg silicon wire.
These will be used inside model slot cars and will need to be disconnected and re-connected from time to time.
Any suggestions please: including the best size / spec. / pitch, and special tool requirements if necessary?
Thanks!
Keith.
jpanhalt
Joined Jan 18, 2008
11,087
Is the wire stranded or solid? Here's a selection of 24 from Digikey.
https://www.digikey.com/en/products...CAAknLCuAq4UiqqIG5+IDIAJkgABEhEcnK4SMJEMXzKQA
You need to define the number of wires/positions and pitch (1 mm or 1.5 mm). At that wire gauge, it seems most are IDC (insulation displacement) type. There are special tool$$ for doing that. If you search on AAC , you will find various methods members have developed to do without those tools.
Keith Pritchard
Joined Oct 15, 2020
7
Thanks very much for pointing me to these data sheets. My wires are stranded. I understand the pitch to be the spacing distance between the pins, if this is not the case please could someone give me a nudge! Cheers.
Keith
dl324
Joined Mar 30, 2015
18,477
Is there a reason why you don't just use JST connectors?
They say they only work for #22-28, but they'll probably work with #30. If it's really not thick enough, double up the wire before crimping.
dl324
Joined Mar 30, 2015
18,477
I did wonder about this but for some reason I didn’t have the wit to consider doubling up!
Necessity is the mother of invention...
I have hundreds of these connectors and wanted to use them with #22 wire. I stuck a stub of thicker wire in with the #22 to crimp.
When I did that, I didn't have the right crimping tool. Now I do...
jpanhalt
Joined Jan 18, 2008
11,087
"These will be used inside model slot cars and will need to be disconnected and re-connected from time to time. "
Those slot cars are somewhat smaller than a Lexus, at least in my experience. I thought the TS needed small.
