Connected to two wire current loop communication
FANDHI
Joined Dec 6, 2019
10
Hi.. My name is FANDHI, I want to connect my controller with a 2 wire current loop communication between the Gilbarco pump and another controller. My goal is to read the data transmitted in the 2 wire current loop communication.
Is there anyone who can help me?
FANDHI
Joined Dec 6, 2019
10
Are the two controllers and the pump equipped with a current loop interface?
Yes, right.
And I have tried connecting the cable, but the data does not appear on my controller (my controller only reads data passing by). For information, my controller is attached to the 2 wire current loop to rs232 converter circuit board
LesJones
Joined Jan 8, 2017
4,191
Have you checked that the way the data is formatted by the pump and the controller is the same. I would guess that at the lowest level the data is 8 bit asynchronous. If it is then you need to know if the baud rates are the same. If these parts match then you will have to check that the higher level protocol matches.
Les.
