Confusion over voltage & current waveforms of a capacitor in a buck converter
ANewYorker
Joined Feb 12, 2024
9
I am learning about the reasons behind the shapes of the capacitor's current and voltage waveforms.
What confuses me about the capacitor's current waveform is how capacitor knows when to start discharging to help maintain a constant output current. In comparison, inductor's current waveform in much easier to understand; it simply charges when the switching is on and discharges when the switch is off.
What confuses me about the capacitor's voltage waveform is that it seems to have no correlation with its current waveform. With inductor, I know v=L(di/dt), so voltage is the slope of the current waveforms. But with capacitor, when I zoom in, current does seems to be the slope of the voltage waveform like i=C(dv/dt) suggests.
Ian0
Joined Aug 7, 2020
13,123
There‘s nothing confusing about it, when you look at it from the right viewpoint.
The current in the load will be the voltage on the capacitor divided by the load resistance - simply Ohm’s law.
If that current is greater than the current being supplied by the inductor, the rest will come from the capacitor.
Load current =Vcap/R.
if (inductor current > load current) then (inductor current -load current) flows into the capacitor and the capacitor voltage increases.
if (load current > inductor current) then (load current-inductor current) flows out of the capacitor and the capacitor voltage decreases.
ANewYorker
Joined Feb 12, 2024
9
OK. That makes sense. How do you explain the relationship between the output voltage and capacitor current? Is it governed by i=C(dv/dt)?
MrAl
Joined Jun 17, 2014
13,686
You should not limit yourself to looking at the individual currents like i=C*dv/dt or v=L*di/dt, what you need to do is look at them both together as a system because that it what it really is.
For the buck, we have the system of ODE's as:
C*dv/dt=i-v/R
L*di/dt=E-v
where
'i' is the inductor current (not the cap current),
'v' is the capacitor voltage (not the inductor voltage),
R is the load resistor value, and
E is the input voltage assumed to be constant.
In the above, you can see that the cap current is not 'i' it is i-v/R, and you can see that
the inductor voltage is E-v with v the cap voltage.
So this is a system, not individual components acting independently of each other.
If you solve that system you will get the actual inductor current and capacitor voltage, and the capacitor voltage is the same as the output voltage in the simple case.
It gets a little more involved as we get into a circuit that is closer to reality. For example, we have capacitor and inductor ESR which would be added to those two equations before solving.
