Yes, there is dusk and i have remove some.
asking for blower fan to remove completely and the fan at body back is also not working.
Sorry key error not blower it is fan with high rpm for removing dust i will take with brush.That sounds like your problem. Don't blow it out with a blower. This can produce static and fry things. Just gently push it out with a brush (like a shaving brush) clean as much dust out as you can around the heatsink and small fan.
No the extra fan with body of CPU for cooling the power led are connected but not working/rotating.When you say fan at the back, do you mean the power supply fan?
If the cpu (processor) or other components get too far above the temp they are designed for they will burn out and could even start a house fire. It's a safety feature that it turns off.Sorry key error not blower it is fan with high rpm for removing dust i will take with brush.
How the temperature get damage to motherboard.?
ok.The other fan not working would have helped it get too hot too.
What's the advantage of using event viewer? It's for viewing software errors and events, your problem is hardware related. This does affect how software runs but the errors will be random however the problem causing the errors doesn't change.The computer has lot of thing to lean.
What is the advantage of using it?
No computer.What's the advantage of using event viewer?
It helps to run complex programs like photoshop (or you could use a paintbrush it helps me too feed my kids (I'm a computer tech and fix these problems for a livingNo computer.
Why we using computer?
How is it helping us?
Start with the basics, do a computer course online or at a local community college and build on that. I started as a computer sales person in the 90's until I worked my way into the repair department of the company I was working for and eventually started my own business 10 years later.I don't know how to use it properly.
how to become computer tech?
by Duane Benson
by Jake Hertz
by Robert Keim
