Complex circuit problem
jdverbek
Joined Aug 31, 2023
I have a question regarding a problem I encountered during exercises. In geometrically “unconventional” circuits (at least to me) I often find myself unable to see whether components are truly in series or parallel, and how I should approach the problem. Mostly it is because of a weird location of a source (in a bridge, in one of the limbs of a delta/wye etc.). Consider the diagram below, where the open circuit voltage Vok should be determined.
Can someone help me with this? Not just the answer, but especially the reasoning behind the approach please.
Alec_t
Joined Sep 17, 2013
15,158
Welcome to AAC!
Ask yourself:
1) Is E an AC source or a DC source?
2) Do the inductors have inherent resistance?
3) Do the resistors have inherent inductance?
WBahn
Joined Mar 31, 2012
33,282
Determining whether two components are in series or parallel (or both, or neither) is pretty straightforward. The following is for a circuit consisting of nothing but two-terminal devices.
Two components are in series if any current that flows in one MUST flow in the other.
Two components are in parallel if any voltage that appears across one MUST appear across the other.
Given a diagram, if two components are connected at a certain node and there are no other components connected to that node, then they are in series. If two components share the same node on both sides, they are in parallel.
To see the latter case, you can highlight each node in a different color, if a particular component is connected to the red node on one side and the blue node on the other, then it is in parallel with any component that is connected to the red node on one side and the blue node on the other.
