Comparators with wired-OR outputs
DickCappels
Joined Aug 21, 2008
10,662
Maybe this is a good time to show us your circuit so we can try to tell if there could be some sort of problems. If two outputs are connected and one comparator wants its output to go low, they will both go low because in a conventional application there is no active pull-up circuit, only that one resistor.
Alec_t
Joined Sep 17, 2013
15,152
can you please elaborate on this ?
If either comparator A output goes low OR comparator B output goes low then, since the outputs are connected, the output C of the combination is low. The resistor is the only thing which can pull the output high.
As AlbertHall pointed out, and MrChips clarified, in positive Boolean logic this is an AND function :- C=A.B.
In negative logic this can be re-written as not-C = not-A OR not-B.
