Comparator with hysteresis
Ian0
Joined Aug 7, 2020
13,259
Hi @Ian0
Please link me to that donated part, if it is incorrect it should be updated.
E
when I originally tried it, and just made SPICE do an I/V plot, it looked exactly as I would have expected. The “ideality factor” is a depth of knowledge of SPICE that doesn’t interest me that much, although probably it should!
ericgibbs
Joined Jan 29, 2010
21,562
hi,
Checking the LTS standard.dio, this is what I see for a number of Zener diodes.
E
.model D1N746 D(IS=1E-11 RS=13.65 N=1.27 TT=5E-8 CJO=5.826E-10 VJ=0.75 M=0.33 BV=3.1 IBV=0.01 Vpk=3.3 mfg=Motorola type=zener)
.MODEL D1N747 D(IS=1E-11 RS=12.8 N=1.27 TT=5E-8 CJO=5.422E-10 VJ=0.75 M=0.33 BV=3.344 IBV=0.01 Vpk=3.6 mfg=Motorola type=zener)
.MODEL GP3V9 D(IS=1E-11 RS=11.84 N=1.27 TT=5E-8 CJO=5.076E-10 VJ=0.75 M=0.33 BV=3.77 IBV=0.01 Vpk=3.9 mfg=Motorola type=zener)
.MODEL GP4V3 D(IS=1E-11 RS=11.84 N=1.27 TT=5E-8 CJO=5.076E-10 VJ=0.75 M=0.33 BV=4.182 IBV=0.01 Vpk=4.3 mfg=Motorola type=zener)
.MODEL GP5V0 D(IS=1E-11 RS=7.708 N=1.27 TT=5E-8 CJO=4.068E-10 VJ=0.75 M=0.33 BV=4.946 IBV=0.01 Vpk=5.0 mfg=Motorola type=zener 500mW)
.MODEL GP5V1 D(IS=1E-11 RS=7.708 N=1.27 TT=5E-8 CJO=4.068E-10 VJ=0.75 M=0.33 BV=5.05 IBV=0.01 Vpk=5.1 mfg=Motorola type=zener 500mW)
.MODEL GP9V1 D(IS=1E-11 RS=5.672 N=1.27 TT=5E-8 CJO=2.523E-10 VJ=0.75
Also checking through @eetech00 lib post
MODEL MD3 D IS=2.5e-12 N=2.20732 XTI=0 EG=0.1
D2 5 4 MD2
.MODEL MD2 D IS=2.5e-12 N=6.92105 XTI=0 EG=0.1
EV1 1 5 6 0 1
ericgibbs
Joined Jan 29, 2010
21,562
I guess you guys need to work that out. GIGO!
hi @Papabravo
The value I posted for @Ian0 was Is=1E -11 value, taken from the LTS standard.dio
This sub cct text, is clipped from the posted AAC link, it shows Is=2.75E-11 for this particular Zener
So I don't follow your dismissal of that value I posted.?
E
.SUBCKT DI-1N4744A 1 2
* Terminals A K
D1 1 2 DF
DZ 3 1 DR
VZ 2 3 13.7
.MODEL DF D ( IS=27.5p RS=0.620 N=1.10
+ CJO=78.3p VJ=1.00 M=0.330 TT=50.1n )
.MODEL DR D ( IS=5.49f RS=0.804 N=1.77 )
.END
Alec_t
Joined Sep 17, 2013
15,156
I was wondering how to model a solar panel without having to join up all the series diodes.
You can simulate a string of diodes by adding n= xx (where xx is the number of diodes) to the end of the diode type parameter, like this:
The voltage at A above is ~7.3V
ericgibbs
Joined Jan 29, 2010
21,562
hi,
This is the asc file for that plot, experiment with the settings.
The 12V source on the Vout is a 12V simulated battery load, delete if not required.
[Note the Is=1n]
I have done some sims for 12V battery charging from this circuit, if you are interested,ask.
Papabravo
Joined Feb 24, 2006
22,111
hi @Papabravo
E
* Terminals A K
D1 1 2 DF
DZ 3 1 DR
VZ 2 3 13.7
.END
I don't think you followed what I wrote very carefully. It was taken from the schematic posted by @Ian0 from the .param statement on that schematic. He then used the value of parameter Is from that parameter statement in a calculation for lower case n which was then used for the diode model "dpv".
See the .param statement on the schematic in post #27 where the expression n=Vmax*38.6/log(Imax/Is) is used. AFAIK that particular definition has nothing to do with any other model except the "dpv" model. If you evaluate that expression using the defined parameters you get what appears to be a ridiculous value. As we have already noticed the letter "N" has overloaded meanings for a diode depending on the scope. Inside the model card is different than outside the model card.
ericgibbs
Joined Jan 29, 2010
21,562
Hi Papa,
From Post #33 it 'appeared' that I had posted an inaccurate value for Is=1E-11, when typically the default value for that parameter when used with a LTS Zener model is : Is= 1E-11
BTW: I do read your posts carefully, but as they say, 'if in doubt, ask', so I did...;)
E
Papabravo
Joined Feb 24, 2006
22,111
The .param statement came with the model.
Well that's a weak defense. I cannot fathom what the original model intended to do. It makes no sense for either of the intended purposes of the parameter n as "number of diodes" or the ideality factor of a single diode unless I'm really missing something.
Papabravo
Joined Feb 24, 2006
22,111
Hi Papa,
E
I was never questioning any use of Is as an actual parameter on an actual diode. I questioned the use of the label Is, defined as a parameter outside of any diode model to compute an expression for "n" which was then plugged back into the model for "dpv".
Ian0
Joined Aug 7, 2020
13,259
It’s the best defence I’ve got. I‘ll add to that “it seemed to work”! Do I need more than two flimsy excuses?
When it produced a valid looking I/V curve, I didn‘t examine it any closer.
Papabravo
Joined Feb 24, 2006
22,111
You get a pass for treading into terra incognita without a good map.
