I want to use two RS232 ic's (Max232) to transfer data to a Arduino Due and then from the Arduino it communicate with the PC (com port) using usb. This work with Arduino mega 2560, but I wont work with Arduino Due, because I want more powerful microcontroller than Arduino mega 2560 (Arduino Due having 32-bit ARM core microcontroller). If I say simply I want to communicate the outputs of the two RS232 ic's which having 9bit's with Arduino Due. Arduino Due having 8bit serial communication bits.
Is it possible to use 74HC4067 multiplexer for this communication between RS232 and the Arduino Due.
Please suggest me a method to do this. Thank you.
