common-source amplifier
anhnha
Joined Apr 19, 2012
904
I am simulating common-source in LTspice and I don't know why there is no amplification at all.
Can anyone explain why? It knows there is something obvious that I don't see.
In common-source Av = gm.Rd but in in my picture Vout and Vin are
same in magnitude.
Here is Vin:
And this is Vout:
33,218
Which node is n002. Don't just say it's the output. Identify which node in your circuit it is.
My guess is that it is the node that connects the resistor to the 5V supply.
33,218
I wonder why my bias is incorrect. I use input signal 3V DC offset and AC amplitude is 1V.
I'm not sure about this, either. What is the threshold voltage for the MOSFET you are simulating?
If you are seeing 5V at the drain of the MOSFET (connection between it and the resistor), then the MOSFET isn't turning on which implies that the threshold voltage is more than 4V.
One thing to do is to plot out the DC transfer characteristic by applying a slow ramp from 0V to 5V (say over 1s) and see what your active region is.
Jony130
Joined Feb 17, 2009
5,600
But in my simulation mosfet is Full ON as expected and Vds = 100uV max and Id = 4.999mA
anhnha must have something wrong with his simulation MOSFET model.
I use this model
.model AO6408 VDMOS(Rg=3 Rd=4.8m Rs=3.6m Vto=1 Kp=90 Cgdmax=.7n Cgdmin=.25n Cgs=1n Cjo=.36n Is=36p Rb=6m mfg=Alpha_&_Omega Vds=20 Ron=12m Qg=18n)
anhnha
Joined Apr 19, 2012
904
Thanks, the threshold voltage is 1V. I was scared seeing too many parameters. I don't have much time and feel really worry now. I will look it carefully and come back again.
33,218
I use this model
I hope I didn't offend the OP by saying "she". I see "anhnha" and my mind reads it as "annah".
Your sim makes more sense.
In the OP's sim, the node voltage is going slightly above 5V, which means some kind of capacitive push, most likely.
anhnha
Joined Apr 19, 2012
904
Hi Jony.
In your simulation Vin is 4mv peak to peak and Vout is 2.526V peak to peak, not exact number because I don't know how to measure it exactly.
From that voltage gain Av= Vout/Vin = 2.526/0.004= 631.5
Does it match with theory?
In common source Av = gm.Rd.
In this case gm = Kp=90, right? Then Av = gm.Rd = 90000.:confused: Where I am wrong?
WBahn:
Not at all!:)
Jony130
Joined Feb 17, 2009
5,600
Hi Jony.
Do you know the theory?
For Vgs = 1.007V and Vp = 1V; Id = 2.2mA
Id = 0.5*Kp *(Vgs - Vth)^2
So
\(gm = 2\sqrt{0.5Kp *Id} = 0.629S\)
And the Voltage gain
Av = gm * Rd = 629V/V
LTspice shows 627.865V I use AC analysis to find a voltage gain.
See my simulation file.
anhnha
Joined Apr 19, 2012
904
Thanks, I was mistaken between Kp and gm; they are not the same.
Jony, I don't understand ac analysis. What does ac analysis do? It analyses parameters with frequency sweep, right?
And how can you plot voltage gain?
anhnha
Joined Apr 19, 2012
904
Do you open the LTspice file that i have attached in the previous post?
Yes, I ran it but I see nowhere in ac analysis they say about voltage gain. And in your simulation, there are two lines, one is dotted and the other is bold. I think they are output voltage and voltage gain respectively but I can't figure out where I can choose to plot voltage gain. Is it automatically plotted in ac analysis?
Jony130
Joined Feb 17, 2009
5,600
I simply set AC input voltage to 1V, next I ran a sim and plot Output voltage.
And since Vin = 1V the Vout is a voltage gain already. Av = Vout/Vin = Vout/1 = Vout.
The bold trace show Voltage gain (in dB or linear axis) vs frequency and dotted trace show phase shift vs frequency.
No, I save a plot setting.
anhnha
Joined Apr 19, 2012
904
Another question, mosfet in LTspice has a lot of parameters such as this one:
Do you usually use most of them? These parameters I don't know when we need to use?
Rg=3 Rd=4.8m Rs=3.6m, Cgdmax=.7n Cgdmin=.25n Cgs=1n Cjo=.36n
