Common Resistors
noteleks
Joined May 10, 2009
5
I am having to buy special resistors for old radios. I have to have a minimum buy. What would be common resistors that are used for different electronic projects? That way I can buy some other resistors that I probably will use later when I expand my hobby to modern electronics. Thank you.
bill2009
Joined Apr 17, 2009
31
what size(wattage) are your radio resistors - do the standard value ones have to be the same? That might make them large for everyday electronics use.
I note that for $12.49 Radio Shack will give you a 500 piece assortment:
Resistors. In an irresistible, money-saving assortment.
Save money with this assortment of 500 ¼-watt fixed carbon film resistors with 5% tolerance. Find exactly what you need for a variety of projects. You'll find 30 each of 1k, 10k, and 100k; ten each of 1, 10, 100, 120, 150, 220, 330, 470, 560, 1.5k, 2.2k, 3.3k, 4.7k, 15k, 22k, 47k, 220k, 470k, 1meg, and 10meg; five each of 2.2, 15, 22, 33, 39, 51, 68, 82, 180, 270, 390, 510, 680, 820, 1.2k, 1.8k, 2.7k, 3k, 3.9k, 5.1k, 5.6k, 6.8k, 8.2k, 12k, 18k, 27k, 33k, 39k, 51k, 56k, 68k, 82k, 120k, 150k, 180k, 270k, 330k, 1.5meg, 2.2meg, 3.3meg, and 4.7meg.
I bought one of these in the winter and it seems to have everytrhing I've needed since. I haven't needed many of the smaller values.
Also, I note that 1/8 watt resistors are becoming common.
Wendy
Joined Mar 24, 2008
23,849
Not for older radios their not. The norm for old electronics is more in the ½W, and 1W, sometimes more. The question is still a good one though, what is the wattage range you are looking for?
What part of the world are you in?
noteleks
Joined May 10, 2009
5
Good question. Yes, I have been to Radio Shack. One resistor that I need is 2 m ohms, Radio Shack only goes up to 1 m ohms. It has to be the 1/2w as Bill states. I am ordering from an online company that does radios. But you have to have a $15.00 min. So I decided that I would also buy resistors that I could use on future electronic projects. Not radio projects though, more up to date stuff. Thank you.
beenthere
Joined Apr 20, 2004
15,819
Check my math if you want - for 350 volts (figuring on highest imaginable B+) and 2M to ground, you get .175 mills. Using I^2 * R, that is 61 milliwatts (.06125 actual). More that I would have thought, but a long way from 1 watt.
