Yes I follow, but if the average or peak currents of each pulse are known along with their voltage and duration it's not too difficult to get a rough estimation of the total available power that may be capturable.
Same with quantifying the relative battery size. Recharging a button cell Vs a sub C multi AH cell Vs a group 31 deep cycle LA battery are all pretty easy to define and be understood by most everyone here.
Good point. I actually do use an inductor and a quite pronounced resonance is clearly evident, far more than I anticipated!Note that half the energy is lost when directly charging a capacitor from a resistive voltage source.
If you use an inductor in a resonant charging scheme you can deliver closer to 100% of the energy to the capacitor
Yes but capturing electrical power from a definable source is nowhere near close in approximation to testing an aircraft with a million plus parts to make sure they all work properly. Especially when the said electrical circuit is a simple three item current conversion circuit made from very well understood and basic components anyone who has any decent working knowledge of electronics can model and approximate with reasonable enough accuracy to make a base determination towards likely output power.Nice in theory, but there's a lot more going on here. Obviously, RMS, pulse width, etc.,etc., are calculable as viewed on the oscope, etc., but, as with all things in real life, actually physical behavior differs substantially from theoretical predictions. This is why airplanes are tested for 10,000s hrs before being packed with passengers!
(impolite language removed by moderator -dc)Yes but capturing electrical power from a definable source is nowhere near close in approximation to testing an aircraft with a million plus parts to make sure they all work properly. Especially when the said electrical circuit is a simple three item current conversion circuit made from very well understood and basic components anyone who has any decent working knowledge of electronics can model and approximate with reasonable enough accuracy to make a base determination towards likely output power.
Since you cannot bring yourself to define anything about the source, or any viable technical references to anything you are using for that matter, I am at the point I feel like stepping out being I have nothing to work with and thus nothing to contribute from here since no working information about anything real has been given for anyone to work with at all.
Reason being, in my online experiences when a thread has gone this far and the person who started it has yet to give one single shred of viable definition of and to what they are working with I tend to assumes its standard overunity nonsense and they just don't want to admit it for any number of reasons.
That and mostly I'm not one to waste my time chasing others dreams of learning something from nothing. I've been there and done that too many times already now to want to bother with it any more.![]()
| Thread starter | Similar threads | Forum | Replies | Date |
Calculating the ripple current for a capacitor in a vfd | Power Electronics | 6 | |
| Y | logic of L_critical and L_ripple in buck converter | PCB Layout , EDA & Simulations | 0 | |
Combining LM2596 buck converter module with LM317 Linear Regulator | Power Electronics | 40 |
