Combining rails
Surtsey
Joined May 8, 2022
15
I have an old PSU that provides +12v 2A and +5v 2A. I'm trying power an amplifier TDA3116D2 that has a requirement of 12-20v. Can I combine the rails? If so, what is the resulting output?
Sidebar: I bought this amp board on Ebay for cheap. I'm confused as to why it does have a heat-sink. Anybody have any experience with this board?
dendad
Joined Feb 20, 2016
4,642
No. The 5V and 12V will have a common 0V I reckon.
But, what is the power supply"? Is it an linear regulated one or a switch mode?
If a linear one, you may be able to use the pre 12V regulator supply.
Papabravo
Joined Feb 24, 2006
22,116
Are the grounds common or isolated?
If they are common, then the answer is absolutely not. You'll let the magic smoke out.
BobTPH
Joined Jun 5, 2013
11,678
If you mean put the 12V and the 5V in series, the answer is likely no. It is possible that the two supplies are isolated and you can, but that would be unusual. If you want to know if they sre isolated, disconnect it from power, then measure the resistance between the two negatives. If they are isolated, it will show high resistance, if not isolated, the two will be connected together and show less than 2 Ohm.
As far as the heat sink goes, I assume you mean “does not have a heat sink”. It should. Every other board I looked at does. You might get by with using at 12V without, but no guarantee.
