Combine multiple pulse waves into one source SPICE netlist
motaha
Joined Jan 24, 2024
Is there a way to create the wave form in the attached image in a SPICE (Xyce) netlist? Each block is 200ms. So, 20 1V pulses with a 10% duty cycle and 10ms period for the first 200ms, then 0V for another 200m, then -0.9V pulses with 10% duty cycle and 10ms period for another 200ms, then 0V for another 200ms.
I tried created four different voltage sources with setting time delays and connect them to the same node, but Xyce returned an error. Any ideas?
Papabravo
Joined Feb 24, 2006
22,113
Put them in series. All the sources that output 0 when other sources are active will contribute nothing to the result. I used this method when I was playing with modified sine wave inverters.
FYI, SPICE will not allow you to connect voltage sources in parallel with no source resistance. That would be equivalent to voltage source butt humping.
motaha
Joined Jan 24, 2024
Thanks! That worked.
