Combination Lock Question
testedoido
Joined Dec 21, 2024
I'm doing a combination lock for a project, and I want to do a circuit that disables the password checker if its check the wrong password 3 times.
This is almost working, the problem is that if it's given the right password, the counter increses too, so it locks even if it's the correct password.
I think the problem is that the counter it's increasing before checking if the led is lit or not (if it's lit, the AND gateb
38,820
So the logical question is, why not change the logic so the counter increases only after checking that the LED is not lit (such as when the selected input switch signal is released?
testedoido
Joined Dec 21, 2024
Thank you for your reply Zapper!
I tried incrementing the counter after the check, and I came up with this:
But it's now incrementing when the led turns up, and dont incrementing when the led is turned off, If i put a NOT before the AND gates, the logic is lost
panic mode
Joined Oct 10, 2011
5,255
what is the purpose for the AND gate between MATCH block and counter?
why you only compare counter with value 3? what if counter value is 4 or 5? (regardless how it got there)
MrAl
Joined Jun 17, 2014
13,793
It's a little hard to see what that yellow block does, and your "Contador" block. It looks like you might be mixing 1 bit lines with multiple bit lines and that makes it harder to decipher what you are currently doing with the logic.
If you need to check the password 3 times, then you need a counter that can count up to at least 3 or 4. Do you at least have that?
