Hi I am trying to control a PWM duty cycle from a potentiometer but its not working as expected.
I have created a bit field for storing the upper 2 bits of the ADRESH register (i.e. left aligned adc) into the 2 bits of c which is put into bits 5:4 of the CCP1CONbits.DC1B. These bits form part of the 10 bit resolution of the CCP module. The other 8 bits come from ADRESL which is put directly into CCPR1L.
bits 7:6 is shifted right by 6 to bits1:0 and put into CCP1CONbits.DC1B.
On my oscilloscope, as the pot is adjusted from left to right, the duty cycle go's from 1% to about 98% then goes to about 25% to 98% again. I'm assuming the ADRESH bits are not being put into CCP1CONbits.DC1B but I dont know why. Can anyone see why and is there a way to directly access the 2 upper bits of ADRESH?
Code:
#include <stdio.h>
#include <xc.h>
#include <func.h>
#pragma config FOSC = INTOSCIO
#include <pic16f785.h>
#include <stdlib.h>
struct mybitfields
unsigned a : 1;
unsigned b : 5;
unsigned c : 2;
}test;
int main()
init_osc();
init_adc();
init_PWM();
init_portc();
delay_1ms();
ADCON0bits.GO_nDONE = 1;
while(ADCON0bits.GO_nDONE);
CCPR1L = ADRESL;
char reg = ADRESH;
test.c = reg >> 6;
CCP1CONbits.DCB = test.c;
while(1)
PIR1bits.TMR2IF = 0;
while(!PIR1bits.TMR2IF);
