Cloudflare Timeout errors?
Hypatia's Protege
Joined Mar 1, 2015
3,228
Kind friends
Please be advised that I have noted several instances of loading issues presenting as "Error 524 a timeout has occurred" accompanied by a graphic purporting to 'trace' the difficulty to Cloudflare servers...
Many thanks for your attention to this matter!
Best regards
HP
WBahn
Joined Mar 31, 2012
33,182
It happens from time to time. I don't know the cause and suspect it might be different at different times. They might have a server down or they might be migrating or syncing databases. It usually seems to last anywhere from a few minutes (if that) to perhaps half an hour (I think I've seen one that lasted quite a bit longer, but am not sure). About the only thing you can do is keep trying until it goes away. I usually use it as an opportunity to simply turn my attention to some other task for an hour or two.
