Cloud Cover light sensor
DJ_AA
Joined Aug 6, 2021
502
Hi All
Can anyone recommend a cloud cover light sensor, that would output data either using UART or i2c?
DJ_AA
Joined Aug 6, 2021
502
I will check them out. If this were to be kept in an enclosure, would you know if there is any sort of protected enclosure we could use? I wouldn't want to use make unnecessary holes and let rain get in
Alec_t
Joined Sep 17, 2013
15,171
For aviation use, cloud cover is normally measured in eighths of the sky, e.g. is expressed as 3/8. Is that what you have in mind?
Ya’akov
Joined Jan 27, 2019
10,370
Ambient light is orthogonal to cloud cover. A cloud cover sensor in practice is a compound sensor using a ceilometer (laser rangefinder checking the cloud base height), infrared sensors, and a camera—along with the program needed to integrate the data from all three.
So, if you want a meaningful cloud cover metric, you are most likely best off using METAR reports that you can get free using the aviationweather.gov API. Metar reports include cloud cover information. The raw METAR report looks like this:
KORD 241251Z 27019G27KT 10SM OVC030 01/M06 A2974 RMK AO2 PK WND 28034/1225 SLP075 T00111056​
The sixth group is the sky conditions which translates roughly to oktas, the standard 1/8 of sky coverage for aviation and others. The three letter code is the condition (overcast in this report) and the 030 is the ceiling in hundreds of feet AGL (Above Ground Level), so 3000‘ in this case.
You can access the report with the a simple URL:
You can also request a report in JSON format.
28,626
Based on that additional information provided in posts #6 and #7, it is clear to me that the TS needs to describe exactly what sort of "cloud cover" they are wanting to know about.
My new suggestion is "a video camera feeding a computer running custom software."
