Total novice here with a clock idea I’m looking for help with.
I want to take a signal from gap in an opaque disk mounted on the seconds hand shaft of a battery operated quartz clock. Using a slot IR I want this to signal a small 12vdc motor to run for 1 rotation, using another slot IR to stop the rotation of the motor. The motor would be geared to produce a 1 minute advance on a 'minute' disc.
Once every full rotation of the minute disc I want another slot IR to signal another small DC motor to rotate an 'hour' disc and have it stop by reading another slot IR.
Leaning on my very limited knowledge I see this would involve transistors and diodes and wondered if anyone could help with the circuit and values for the components ? There's probably a better way to accomplish this but I'd rather not involve arduino or code for simplicities sake.
Cheers
Phil
Cheers
Phil
