Clock frequency
22,116
I dunno -- What are your requirements for frequency, stability, accuracy et cetra. How can we answer your questions if you fail to supply any information?
beenthere
Joined Apr 20, 2004
15,819
Get a TTL or CMOS oscillator. Mouser and Digi-Key carry a wide selection.
Here is a link to a manufacturer so you can get an idea of the frequencies available - most are standard -http://www.well.com/~oe/OscFreqs.html
patheticz
Joined Nov 3, 2009
28
Sorry for the lack of information
First of all, the query arose because i am designing an embedded controller for a a power switching module that is supposed to be able to function at swtiching freq of at least 10kHz.
then i was looking through the specification sheet and realized that the Virtex 5 and virtex 6 FPGA can operate at 400MHz -1000MHz.
Therefore, i was not sure what methods can i use to generate signal for the clock if i am going to use either of the FPGA
22,116
Those frequencies are maximums. There is absolutely nothing that says you have to operate at such frequencies. In any case the way you genrate 10 kHz from a crystal or other type of oscillator is to pick a convenient frequency and divide it down.
patheticz
Joined Nov 3, 2009
28
i am a bit confused here.
does that mean by having an oscillator of 10kHz, i can also generate frequency that is higher than that?
