Class D output filter high impedence
artmaster547
Joined Jan 6, 2016
409
Hi all
I have an issue I want to use a class D amplifier to drive a piezoelectric load, I am modelling this as just a resistive load of 400 ohms, (37.5W, voltage swing between +175V and -175V). Could anyone suggest what kind of filter I should use on the output, the class D FETs will be driven at a minimum frequency of 100kHz and I need a AC sinusoidal output of 1kHz? I have seen it being traditionally with an LC filter when calculating these values I got an extremely large inductance of 59mH, and wondered if anyone had any suggestion if I could use anything else that uses components of smaller magnitudes and are more accessible?
Kind Regards
Art
Hymie
Joined Mar 30, 2018
1,347
With the parameters you have given (+/-175V switching at 100kHz into a 400Ω resistive load), using LTspice - with a filter made up of a 10mH inductor followed by a 0.1uF capacitor (to 0V) reduces the switching voltage to around 5V (peak to peak) at the load.
If you play around with these values (or add a second filter stage), you could reduce this voltage further.
artmaster547
Joined Jan 6, 2016
409
By reducing the switching voltage do you mean the filter attenuates? So rather than the load seeing +/- 175V it sees +/- 5V?
Hymie
Joined Mar 30, 2018
1,347
The D class amplifier is switching the output at high frequency; the audio frequency modulates the high frequency such that at 1kHz, the above filter is applying virtually no attenuation, so the 400Ω load will see 1kHz (350V peak to peak) – but the high frequency component is removed.
