Circuit won't turn off
TexasBluesGuitar
Joined Feb 27, 2015
4
Hello all, I am a newbie to electronics and circuits, but am a professional programmer. I have dove into the IoT and am now learning all about circuits. So here is a question related to a real life situation. I tried to change the light bulb in my bathroom. The light bulb is in the middle of an 8 bulb above mirror fixture. I left the power on while I was changing the bulb. During the change as I was screwing it in a massive spark happened and the bulb failed to turn on. Now the dimmer switch cannot turn off. It does not work and the lights have been on all night. This time I am going to shut the power off to the house and change the bulb, but I think the switch is broken. What do you all think?
Texas Blues Guitar
34,829
When you unscrewed the light bulb with the power on, it caused a short circuit across the contacts. All eight bulbs are wired in parallel powered by the light dimmer. The thyristor in the dimmer is blown, failed short.
You can replace the thyristor with Q4006.
18,108
I think you should turn off the appropriate circuit breaker, not all of them, and have an electrician come take a look.
I speculate that a poorly installed fixture - perhaps installed by the previous owner? - may have caused an intermittent short when you wiggled it and that short damaged your dimmer. It likely needs to be replaced. Just speculation.
You can do this work yourself as long as you keep safety in mind at all times. Get a circuit tester or multimeter so you can detect whether a circuit is live or not, and use it before you touch any conductors.
30,675
I am guessing when the lamp was screwed in the lamp holder turned and shorted the L&N together, it should also be checked by dropping the fitting of the wall and check the wiring otherwise the same thing may happen the next time you change the lamp.
Alec_t
Joined Sep 17, 2013
15,121
Whatever you do, first ensure the circuit-breaker for the light circuit is OFF before dismantling the light fitting.
ErnieM
Joined Apr 24, 2011
8,415
Don't buy anything, don't take anything apart.
Make the call and hire a licensed electrician to replace the failed dimmer.
darrough
Joined Jan 18, 2015
86
You should be aware that if work is not done by a licensed electrician, and anything subsequently happens that might even been possibly caused by said work, your homeowners insurance will not cover any of it.
34,829
Assuming the dimmer switch looks like this:
Step 1. Turn on the bathroom lights.
Step 2. Go to the service panel and turn off the breaker feeding the lights. Confirm that the lights go off.
Step 3. Remove the control knob by giving it a firm pull.
Step 4. Unscrew two screws holding the dimmer switch cover plate.
Step 5. Unscrew two screws securing the dimmer switch.
Step 6. Disconnect the three wires connecting the dimmer switch while making notes on which wire goes where.
Step 7. Replace the dimmer switch with a new one from your local hardware store.
Step 8. Reassemble switch and cover plate (follow steps in reverse order).
Maybe your switch looks like this:
If so, here is the manual:
http://www.smarthome-products.com/productspecs/2209wi Manual.pdf
TexasBluesGuitar
Joined Feb 27, 2015
4
Thanks all. Yes it looks like the second switch. I am now thinking about replacing the whole fixture with a string of 12V LED lights. I dont think i need house ac current for that. Maybe a 12V adapter attached to a potentiometer in some kind of circuit. This is where my noobiness shows. Or should I replace the dimmer and build a 12V adapter for inside the switchbox with the dimmer style like the first picture? Then I could us the original wire used to connect the old fixture,
TBG
18,108
I agree with MrChips' prescription. It's exactly what I would do. No way would I try to repair a damaged dimmer.
I would add a step or two to look at the fixture while its power is off. I'd take it off and look for wires that are kinked or have frayed or scarred insulation, look burnt or anything else that looks amiss. Maybe a socket that has broken loose so that it rotates when you turn the bulb.
If you want LED bulbs, replace the existing bulbs with those. Be sure to get dimmable ones.
