Circuit theory problem
AlbertHall
Joined Jun 4, 2014
12,640
Please show your attempt at the answer then we can congratulate you if you get it right, or offer suggestions if you get it wrong.
MrAl
Joined Jun 17, 2014
13,775
I did another enhancement of Burtus' enhancement and still cant quite make out the characters in the last line of the supposed solution.
If it was to be done that way, i cant be sure if his version is right or not because of the handwriting :)
To the OP:
If you can at least clear up the handwriting i could at least check your result the way you did it.
WBahn
Joined Mar 31, 2012
33,080
To the OP:
Alas, another call to the virtues of heeding The Proper Care and Feeding of Homework Graders.
When you are asking others to look at your work, take the time and effort to make it worth looking at -- or at least easy to look at. It's hard to tell in which situation that is more valuable -- when asking strangers to provide feedback for free, or when asking the person grading it to assign a grade that will be reflected on your transcript.
MrAl
Joined Jun 17, 2014
13,775
Now it looks like he is not coming back either :)
