circuit solutions how to switch battery packs correctly AND achieve galvanic isolation
krishnasai228
Joined Apr 1, 2022
Hallo,
I am doing a project to charger the battery packs, from an IC charger BQ25792,
Generally I am using 3 packs and each can be charged one at a time by the IC charger and others are discharging.
I need to connect the battery packs in order to achieve galvanic isolation and also circuit solutions how to switch battery packs and achieve galvanic isolation so that the switch can seamlessly switch accordingly.
I used the switches as N- MOSFETS
Could you please tell me any solution in detail and i attached block diagram.
Thanks,
Saikrishna reddy
38,948
If you need total isolation between the two grounds (why is that?) then you will need to use relays, either mechanical, or solid state relays that use optical coupling for the control signal.
krishnasai228
Joined Apr 1, 2022
Thanks for the reply,
Is it better to use relays or semiconductors like mosfets?,
Can i able to use mosfet to achieve galvanic isolation?
38,948
To use a MOSFET, you would need to use an isolator to switch it, such as a opto isolator, or an SSR (Solid State Relay) which has the opto isolator built in.
Relays are already isolated since the contacts have no connection to the actuator coil.
As to which is better, the MOSFET/isolator would be smaller and have a longer life.
The relay is simple, but is larger and takes more power to actuate.
Hymie
Joined Mar 30, 2018
1,347
One observation, you have used double pole switching to isolate each battery in charge and discharge mode – whereas single pole switching will suffice.
