Circuit Oscillating but no output
Audioguru again
Joined Oct 21, 2019
6,826
There are lots of simple circuits on the internet. e.g.
This simple circuit like others on the internet slowly destroys the BJT transistors because the maximum allowed reverse emitter-base voltage is exceeded (avalanche breakdown) each time a transistor turns off. The maximum allowed reverse emitter base voltage of most little transistors is only 5V or 6V but here they get almost 12V. A diode and resistor added to each transistor will fix it.
Google shows many circuits that have a multivibrator made with two Mosfets that produce a squarewave:
38,849
Is a square-wave out okay or would you prefer a sine-wave?
Of course that would require much more circuitry to generate a sine-wave modulated PMW signal to drive the transformer.
38,849
One way to get 120V peak out of that transformer is to drive the 12V side with a MOSFET bridge circuit from the 12V.
That will put ±12V across that 12V winding which will give ±120V from the 120V winding
You will need a proper bridge driver with non-overlapping signals to drive the bridge and avoid large current shoot-through during the switching time.
I have a circuit for that, if interested.
Miracletech
Joined Nov 15, 2019
160
May I see please?
38,849
May I see please?
Below is the LTspice simulation of a non-overlapping clock driver with a complementary MOSFET bridge. The driver circuit uses three IC packages.
The NOR gates generate the non-overlapping function so that the top and bottom adjacent MOSFETs are never ON at the same time (the second and third magnified plots show this non-overlap for both rising and falling waveforms).
[Remember that the N-MOSFET gate (yellow) is high when ON, but the P-MOSFET gate (blue) is low when ON].
This prevents the high shoot-through current that would otherwise occur when the two transistors are momentarily on simultaneously during switching.
The red trace shows the ±12V waveform across the transformer winding (R_Trans).
Two CD4049 CMOS HEX inverter chips are used with three parallel outputs for each gate as a poor-man's push-pull circuit to drive the large MOSFET gate capacitance.
For driving a transformer, the input waveform should have an exact 50% duty-cycle.
That can be achieved by setting the 555 frequency to 100Hz and running that through a CD4013 flip-flop configured as a divide-by-2 toggle (/Q output to D input).
The 555 duty-cycle is thus not a factor, as the FF triggers on only one edge of the clock.
Note: Not shown, but required, are 100nF ceramic caps across each chip from their power pin to ground pin, as well a large (e.g. 100μF) cap from the bridge Vdd supply node to the bridge ground.
