circuit notation
beenthere
Joined Apr 20, 2004
15,819
What notation is strange - resistors, diodes, or the clearly backwards direction of current? We seem to have a permanent stream of conventional vs. actual current flow direction questions.
keltix
Joined Jan 10, 2010
6
just that the circuit is not connected..
and i think i had it wrong: the first one would be equivalent to a 2V battery.....
scythe
Joined Mar 23, 2009
49
Hey there Keltix, I'm not going to do your homework for you, but it IS helpful to have a good example to go off of...
... so here it is. :)
I think the equivalent circuit is the one I've posted below. You know that the bottom is at -1v potential, so you just use the 0.7v model for the diode (this models the voltage necessary for the diode to be forward biased-- without this you have an open circuit that does not conduct! :(), and add the 0.7v drop to figure out what Vout is. Once that's done, you can find the current going through your resistor, and because Vout is an open circuit, you know that the same current has to be going through your diode, and you have thus solved I.
If I'm wrong, somebody correct me, but I think that's right...
SgtWookie
Joined Jul 17, 2007
22,230
In the leftmost circuit, the total potential is 2 Volts across the resistor and diode.
What do you think the voltage will measure across the diode?
SgtWookie
Joined Jul 17, 2007
22,230
Ask yourself, "What is the maximum possible current that could flow from the most positive source to the most negative source?" Keep in mind that the 130 Ohm resistor will limit the current flow, if nothing else will.
