Circuit for timed switching of polarity?
dbarak
Joined Sep 15, 2018
9
Hi Alec_t,
I found an article on Wikipedia about flyback diodes, which is what came up for a search for "reverse-bias diode snubber," so I assume this is the same thing. The circuit diagram shows the diode in parallel with the L inductance and R inductor windings. Do these two together represent the solenoid coil? (If my understanding of L is correct, it's not a physical component, but rather an effect of the switching.)
https://en.wikipedia.org/wiki/Flyback_diode
A reverse-biased diode should suffice.
AnalogKid
Joined Aug 1, 2013
12,287
For a circuit like that, use a double-pole relay so the load contacts are completely independent of the oscillator contacts.
Note that this circuit has a very asymmetrical output. The relay coil is energized for a much longer time period than it is de-energized.
ak
dbarak
Joined Sep 15, 2018
9
I've got a DPDT relay so I should be good there. Thanks!
ak
