I want to control an SX1278 radio module with an 18LF2520 PIC with LCD, and program it with a Pickit3.
The SX1278 is a 3.3V MAX device and needs SPI to set it up, plus other connections.
The 18LF2520 will work on 3.3V or 5.V
The PICKIT3 uses 5V (5V suggested in the set-up) to program the PIC.
From tests, I've found that a 5V LCD will power from 5V and work with 3.3V DATA.
When wiring the circuit (using fuse wire) I connected the Pickit3 external power to the 3.3V. After programming the PIC runs if I use the external power from the Pickit3 circuit, but not when powering the circuit with it's 3.3V regulator.
I can't tell yet, but I will most likely have blown the radio circuit?
Can anyone tell me how I should have wired it up, to allow 5V programming, while not blowing the 3.3v units please?
Camerart
Camerart
