Thanks.There are electrometer grade OP amps such as this one: http://www.ti.com/product/lmp7721/description
Should I use Current amplifier or Voltage amplifier? for U1 and U2?
I hadn't seen this thread for weeks.Hi.
I hope you all OK. I wasn't active much lately and I am back to business.
I tried to re-create the circuit @MikeML designed but I have a few problems - please see picture attached. I don't know what is the problem but the Voutput and Ioutput is not the same as seen in the graphs above. Any suggestions where is my fault?
This was already fixed. It was a drawing mistake I did while copying the design.I hadn't seen this thread for weeks.
Why did you connect the feed back to the opamp directly from its output pin instead of from the current sensing resistor as I showed in my posts?
This was checked and no problem with the bus-wiring connection.Make sure R4 is connected to what you think it is on the top bus with an ohmmeter. Some breadboards split the upper lower rails into 8 sections rather than 4 as your breadboard shows. e.g. the upper rail is split in the middle so the top of R4 may not be connected to anything.
Sagi, glad you got it working......Now we need to make it less noisy![]()
