Does every branch of this problem has no effect of the other branches ?
so the current i is basically
i=2/40 ?
i=2/40 ?
I prefer straight lines and would typically draw the components in a vertical configuration, but yes.something like this?
Agreed. Once you have your drawing, making it easier to visualize and analyze the circuit, try removing any one of the legs. Does the solution change? If it does, then they are not independent.The voltage from 'a' to 'b' is a function of all three branches interacting.
Hi,something like this?
| Thread starter | Similar threads | Forum | Replies | Date |
| M | Circuit Analysis Problem: find and Any help would be highly appreciated. | Homework Help | 12 | |
Circuit Analysis problem eluding me... | Homework Help | 18 | |
Circuit Analysis Problem | Homework Help | 6 | |
AC circuit analysis problem | Homework Help | 11 | |
Problem about Summing Amplifier on LTSPICE | General Electronics Chat | 9 |
