Circle Problem
Wendy
Joined Mar 24, 2008
23,857
I need to know the radius of a circle, that matches the following measurements, I think I have enough data to solve the problem but I am not sure how ro go about it. Any ideas? The dimension given are sloppy and approximations only.
.................................................................................................................Circle  Problem.png
33,261
.................................................................................................................View attachment 191427
b = (0.65")/2
a = (R - 0.20")
R² = a² + b²
R² = (R - 0.20")² + [(0.65")/2]²
R² = R² - 2(0.20")R + (0.20")² + (0.65")²/4
2(0.20")R = (0.20")² + (0.65")²/4
R = [(0.20")² + (0.65")²/4] / [2(0.20")]
R = 0.364"
Check:
a = 0.164"
b = 0.325"
R = 0.364"
Pythagorean sum checks good.
MrAl
Joined Jun 17, 2014
13,819
Here is another way.
Start with the general equation for a circle:
r^2=(x-h)^2+(y-k)^2
Now form three equations with dimensions extracted from the drawing shifting the x axis for convenience:
1. x=0, y=0.2
2. x=0.65/2, y=0
3. x=-0.65/2, y=0
That gives you three equations in the three unknowns r, h, and k.
Solving that set of three equations, we get two solutions:
r=-233/640,h=0,k=-21/128
r=233/640,h=0,k=-21/128
since h and k dont matter, we get the required radius:
r=233/640=0.3640625
If we stick with the actual dimensions instead of shifting the x axis, we get a different set of three equations using the actual x,y pairs:
0,0
0.65/2,0.2
0.65,0
and we get solutions:
r=-233/640,h=13/40,k=-21/128
r=233/640,h=13/40,k=-21/128
and so here we get the radius and the actual circle center offsets.
33,261
I prefer my way :)
Since my way got me paid several hundred dollars by a high-end carpenter that wanted an equation that would let them calculate the needed radius of a circular arch out in the field, I kinda prefer mine. I didn't even expect to get anything for it -- I just spent worked out the solution and sent him a formula in where he could plug in the width of the opening and the height of the arch above the side walls and figured that was good. But he said that it saved him so much time and all of his fellow carpenters loved it so much, that he wanted to pay me a fraction of what the time that it saved them was worth so that I would be willing to do other things for them in the future.
ci139
Joined Jul 11, 2016
2,037
. -- the fuzzy construct is only for completing the schematic - the formulas are shown for the scaled projection of the original sketch /!\ = you should use the values of the not scaled H , W , M , R , etc. . . .
chk. R = ( W² / H + H ) / 2 = [ W = 0.65" / 2 , H = 0.2" ] = 233 / 640
