Hi, i'm trying to use an AD623 in LTSpice.
The setup: It is a differential amplifier, that i've got set with a gain of 1. ie: I apply a voltage of 100mV on the differential input, I expect an output of 100mV. The purpose of this amplifier is to remove a common mode voltage, and lower the impedance of the signal. I have the amp set up on a single supply with both input and output referenced to ground right now. I've narrowed my problem down to what seems like the output resistor. I've cut it down to as simple as i can make it, and do not understand the output i'm getting.
The problem: the simulation outputs 25.5V with a 10k load resistor, or a 30k load resistor. The output tracks the input, as it should, if the load resistor is 15k. The datasheet mentions on page 23, "The AD623 is designed to drive loads of 10 kΩ or greater." but i can find no other limitations that I'm infringing on. Output reference (REF), according to the datasheet, can swing from rail to rail.
10k Load...
15k Load...
30k Load...
Resources:
The model is available here: https://www.analog.com/en/license/s...spice-models/ad623.cir&modelType=spice-models
Datasheet here:https://www.analog.com/media/en/technical-documentation/data-sheets/ad623.pdf
I've attached my spice model.
Any advice/explanation seriously appreciated!
10k Load...
15k Load...
30k Load...
Resources:
