Choosing between 2 Motor Speed Controllers, for a 5v Fan for a Mini-PC
Zohar
Joined Nov 19, 2015
70
Hi All
I bought several 5v Fans (Brushless) for use as cooling for Raspberry Pi and other Mini-PCs.
All the fans that I bought use a relatively low current (relative to motors..), about 100-150mA maximum.
I would like to be able to control the speed of those fans, manually,
and so I searched eBay for the words motor speed.
2 results that repeat there quite often, are these:
The Red:
4.5-35v, 5A, 90W, 20KHz
https://www.ebay.com/itm/3V-35V-12V...Adjustable-Switch-LED-Fan-Dimmer/132270456321
The Black:
5-16v, 10A, ??W, ??KHz
https://www.ebay.com/itm/DC-5V-16V-...-dimming-10A-Ultra-Switch-Module/153325681507
All of them are good for 5v,
and all of them are way beyond the 150mA of current that I need.
So in that area, they will all be good.
Yet there might be some differences,
for example the red one has a big Electrolytic capacitor.
The black one does not have a capacitor,
or maybe there's an SMD capacitor there that is much smaller.
What effect does it have on the module's operation?
And any other thing that might help choosing between the 2?
If you can, looking at their components, tell which one is better, that would be really helpful.
Thank you very much
Zohar
Joined Nov 19, 2015
70
Hi Dodgydave
In the picture of the second one (the black one), we can also see that it contains an NE555,
so doesn't this mean that both are PWM?
shortbus
Joined Sep 30, 2009
10,049
Pretty sure neither of them will work with a brushless motor(BLDC). BLDC motors are electronically commutated and using a dimmer type control like you linked to will only lower the voltage into the motor, not the speed of rotation. For a BLDC they use an ESC electronic speed controller, and if the fans you have will run without one that means the controller is built into the fan, something very common in PC fans.
Zohar
Joined Nov 19, 2015
70
Well you raise a good point that I might've not been aware of.
Here is 1 fan that I purchased:
https://www.ebay.com/itm/5V-6cm-60m...r-PC-Computer-Cooling-Cooler-Fan/253927366875
It is 6cm in diameter.
The second fan is extactly the same manufacturer and same model, just 8cm.
Still Brushless
Both fans have only 2 wires: 5v, and Gnd.
They do not give any feedback regarding the current RPM.
So does this mean that the 2 Motor Speed Controllers that I showed above are not relevant for these fans?
30,810
Those are typically BLDC fans, but have a DC supply and an internal sensor IC and electronics for control, some have varied the input voltage to regulate speed, you might want to whip up a simple 555 PWM controller to try it.
I have not used them this way myself, just hearsay.
Zohar
Joined Nov 19, 2015
70
The Black controller above has an NE555 on it.
On the Red module I cannot see an NE555 in the picture, but it is declared as PWM, so it should work similarly to the Black one..
So will they be good for it?
Shortbus wrote above that he thinks the modules will not be a good match for them..
30,810
The ebay controllers mostly use the 555 in a PWM mode, it is a toss up whether they will work with those motors, the ebay version is cheap enough if you want to give it a try, or as suggested, put one together if you have the 555.
Basically you are just reducing the mean DC level.
Zohar
Joined Nov 19, 2015
70
So from what you say,
If they won't work with the fans, then neither an NE555 that I put on a breadboard for testing..
What exactly is the problem? The fact that a BLDC otor has some circuitry inside?
Why doesn't PWM "pass" this circuitry and affect the speed?
(If it lowers the voltage, it should affect the speed, no?)
30,810
The DC for the fan feeds an electronic commutation circuit and has the magnetic sensor built into the IC, using a external PWM in place of the DC , just by varying the DC level, this has the effect on speed of the fan.
Generally the fan design is not really intended to be used this way, but some have had some degree of success.
Zohar
Joined Nov 19, 2015
70
I see,
so PWN in general should be avoided.
What about supplying diferent DC myself?
e.g. instead of 5v to give 3v?
(flat DC, not PWM..)
Will that work with them to reduce the speed?
30,810
You could try the lower DC first, I didn't say that PWM should be avoided, it is an option to try, which evidently has been used by others in some cases.
Alec_t
Joined Sep 17, 2013
15,156
A method I've used successfully for speed control of a 2-wire BLDC fan is to connect a biased-on transistor (BJT or MOSFET) as a low-side switch for the fan, have a current-sense resistor in series with the switch, use a comparator to detect when the fan's internal commutation causes periodic dips in the sensed fan current, use the comparator output to trigger an adjustable monostable circuit, and use the monostable output to turn the transistor off, thus extending the current dip interval. This effectively modifies the commutation in a synchronous, non-conflict way and gives wide control of the speed. Depending on the internal commutation, there's no guarantee it would work with all BLDC motors.
Zohar
Joined Nov 19, 2015
70
Extremely advanced for me.. :)
Any chance for a really simpler solution, even if it means not as good as the one specified?
