TimBuckedTwo
- Joined Nov 12, 2023
- 6
OK so I thought I lost all my work I did to make a legible and hopefully clear to understand, and more important correct manual. I was reviewing it, to make sure it was still the latest updated file, getting ready to up load it to Google drive to share, and I read a part that I had forgotten about and may have contributed to you not being able to make it work.The Russian manual (аналогичнрго relay TDM ELECTRIC TE-C TЭ-AC TE-AC) said you program an on/off time close to your sunrise/sunset time (for that day) and the unit then tracks and shifts that time accordingly. But I've tried everything and it just acts like a timer only. Pulled my hair out because the English manuals are the worst I've ever seen.
The little
must be showing in the programming of the On/Off times. If it is not there then the times will not auto adjust. That could be the problem."
If the Astro Function is not needed, press
button to extinguish
So the programs of time will not automatically adjust to the Astro Function.
I can send you a link to G-Drive if you are interested.
