Charging a 48V bike battery with a 12v portable solar pannel system
JFG
Joined Dec 17, 2017
I've looked at a bunch of posts and have seen conflicting info. Is this possible? Most off the shelf bike battery systems are closed so difficult to isolate 12V subsets.
Thanks,
John
dl324
Joined Mar 30, 2015
18,296
Welcome to AAC!
You'd need a boost converter (step up voltage regulator). If you can't access the individual 12V batteries for periodic normalization, battery life will be limited by the weakest.
JFG
Joined Dec 17, 2017
Thanks Dennis. Will look at that.
I'm not even sure they are 12 volt batteries. Think they may be banks of small lithium batteries around a volt or so. They've got odd form factors (cylindrical and sometimes triangular) that make me think this, plus I've seen some articles about people building their own to get more amp hours.
Regards,
John
dl324
Joined Mar 30, 2015
18,296
Whatever battery chemistry they are, make sure you follow the correct charging algorithm.
You can't connect mismatched batteries in series or parallel and expect good results.
spinnaker
Joined Oct 29, 2009
7,830
Welcome to AAC!
Keep in kind if you increase voltage with the boost inverter you decrease current. You need enough current to charge the battery. That is going to need to be one hefty single 12V panel.
You might be better off putting 4-5 panels in series. You also want a charge controller or you could over charge your battery.
spinnaker
Joined Oct 29, 2009
7,830
Regards,
John
YOU DO NOT want to mess with charging lithium batteries unless you know exactly what you are doing. Best case you burn something down, worst case you kill someone. Not even worth taking the risk. Buy an approved charger and charge form your house current.
JFG
Joined Dec 17, 2017
Thx everybody.
I'm looking at a foldable 120 watt solar system with controller to use on an extended ebike trip, one where I may not have access to house current. This system is advertised to be compatible with lithium batteries. The bike battery system is 36 volt, 10.5 ah. The solar system is 12V. I could buy 3 of the solar systems (3 x $299/system) but that seemed like overkill, but I don't understand the math which is why I'm asking. 120w and 12v gives 1 amp. 10 amp hrs means I need 1 system for 10 hours full sun, but that's if the battery was 12V. It's not, and I'd like to get a charge time that's 1/2 of that.
Thx.
