charger circuit explanation
Status
Not open for further replies.
alimash
Joined Oct 12, 2016
67
this circuit is the first part for an emergency lamp circuit, it charge the batteries while the power is on and light the led when the power is off
i can not understand how it works?
can anyone help??
Kermit2
Joined Feb 5, 2010
4,159
It is a transformerless power supply.
The diodes rectify the current to one polarity.
The 2.2 uf capacitor limits current into the diode bridge.
Kermit2
Joined Feb 5, 2010
4,159
Do you understand how a 4 diode bridge rectifier AC into pulses of DC?
The only change here is a capacitor is limiting the AC current instead of a resistance or an inductance of a transformer.
alimash
Joined Oct 12, 2016
67
yes,i do
i think that there is a mistake in the circuit
the bridge is not connected properly!!?
Kermit2
Joined Feb 5, 2010
4,159
The bridge is drawn correctly.
The 100 uf capacitor is where the load, or battery would be.
One diode junction is grounded and the other is giving out only positive peaked pulses of DC current.
There is no mistake in the diagram.
DickCappels
Joined Aug 21, 2008
10,661
The discussion of this kind of circuit is not permitted out of concern for the safety of people who might attempt to built it.
  1. Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Any kind of jammers (ie - Phone jammers)
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    If You come across a thread or post discussing any of the above topics please report the thread so We can close, and if necessary remove, the offending thread/posts.
Status
