channel selector using an IC and momentary switch?
Tomadws
Joined Apr 15, 2016
8
I'm working on a guitar effect stomp box that uses diode clipping. I would like to use multiple arrangements of diodes to achieve different clipping sounds (4 minimum, 8 maximum arrangements.) I would like to use a momentary switch to cycle through all the arrangements in a sequence. Im sure this can be achieved utilizing an IC and/or transistor circuit but I don't know what would work best. Any help is appreciated!
GopherT
Joined Nov 23, 2012
8,009
Can you sketch out the various configurations you need? Just pencil paper and snap a photo. We don't need fancy.
Tomadws
Joined Apr 15, 2016
8
Basically, 1 input that would be a signal in from the effect, and at least four switchable outputs. I suspect I could use a designated voltage and a momentary switch to trigger the circuit to sequencer through outputs? Am I too far off?
absf
Joined Dec 29, 2010
1,968
Yes, you could use half of a 4 to 1 multiplexer like 4052 and a 2 bit binary counter as the A/B address select of the channel. The button is connected to the input of the counter.
Allen
38,856
A couple observations if you use a counter and a multiplexer:
Note that multiplexer signal voltage limits typically go between the plus and minus power supplies.
What power supply voltages do you have?
The switch to index the counter must have a debounce circuit to avoid multiple counts for each switch press.
Alec_t
Joined Sep 17, 2013
15,158
Wouldn't you also need some way to know which output is currently active, and/or a way to 'reset the counter to zero'?
GopherT
Joined Nov 23, 2012
8,009
The 4 inputs of a CD4066 bilateral analog switch could be connected and the chip used as a multiplexer.
Then you need a second multiplexer (e.g. 74151) to trigger the switches for each switch of the CD4066.
Then you need a counter to rotate through each channel on the 74151
And finally, a debounced switch for you to pulse the trigger the counter.
Issues would be the DC bias because the analog signal has to be between the + and - voltage supply of the CD4066 chip. For simplicity, that a hip allows a +9 to -9 volts if you have a split power supply (or even two 9 V batteries in series with ground being the node between the two batteries.
Tomadws
Joined Apr 15, 2016
8
Awesome, thanks for the ideas. This gives me a good place to start. Dual power supply isn't a problem and I can build the circuit to accommodate voltages needed.
