Change this circuit to 12 volts
Aurion45
Joined Aug 7, 2011
64
Hi Everyone,
I'm thinking of making this circuit for a project for a friend new letter box, to illuminate with Leds over letterbox numbers.
I want to make this circuit in 12 volts version.
I will upgrade the following:
Solar Panel to 12 volts @ 10 Watts http://www.rpc.com.au/catalog/cnpv-12volt-solar-panel-10watt-p-2701.html
Battery 12 volts @ 15Ah
I will change the BD140 for TIP32 as the TIP32 is to energised a 12 volt 3 Amp relay, as I'm running more Leds then below.
Do need to beef up the circuit anywhere else.
Any help would be greatly appreciated
ericgibbs
Joined Jan 29, 2010
21,485
Hi Scott,
Which suggests more LED's and a possible change of LED type.
E
Aurion45
Joined Aug 7, 2011
64
53 @ 3.6 volts 20mA Leds, arranged as below.
3 amp contacts on relay Yes you're right.
Solution: 3 x 17 array, 2 extra LEDs =53 leds
3 x 17 leds
1 x 2 leds
R = 68 ohms
R = 270 ohms
The wizard says: In solution 0:
  • each 68 ohm resistor dissipates 27.2 mW
  • the wizard thinks 1/4W resistors are fine for your application
  • the 270 ohm resistor dissipates 108 mW
  • together, all resistors dissipate 570.4 mW
  • together, the diodes dissipate 3816 mW
  • total power dissipated by the array is 4386.4 mW
  • the array draws current of 360 mA from the source.
ScottWang
Joined Aug 23, 2012
7,503
When the current reach up to 100mA then it will be generate the heat, and I guess your application will be get over more, so if you considering the heat then may be using the P mosfet is another options or using a pnp and one n mosfet.
Aurion45
Joined Aug 7, 2011
64
I don't understand, as I'm not very good at electronics?
I will draw up a new circuit tomorrow then ask if it is OK.
ScottWang
Joined Aug 23, 2012
7,503
1. Why you still want to use a relay when the transistor can do the job, but maybe you will need a heat sink for the transistor.
2. if you want to using the relay then the transistor will no need so big, the 2SA684(1A) or similar transistor can do the job.
3. If you using the mosfet has low Rds then may be you don't need the heat sink and relay, because it will reducing the power consumption, you just need to care about the power consumption of LED.
Aurion45
Joined Aug 7, 2011
64
OK if I use a mosfet, how do I replace it for the transistor? what type of Mosfet, eg device number?
I've no clue how wire this in the circuit.
ScottWang
Joined Aug 23, 2012
7,503
The circuit is easy, I can do for you, also other members can do, now just waiting for your circuit and total current, and is that just 360 mA?
Aurion45
Joined Aug 7, 2011
64
Can I use the Mosfet from terminal 3 of the 555 timer?
What type of Mosfet is it? as in device name, so I can buy it, please don't forget need to at least 1 amp, so I can add more Leds if I want too?
ScottWang
Joined Aug 23, 2012
7,503
Two kinds of circuit using N/P mosfet, the n mosfet is more easy to get one to suit your need, if you insist to use the relay is ok, just don't forget to using the 2SA684 to replace the TIP32.
The below are the p mosfet to suit your need, if you choose p mosfet then you should concern the price and which one you can get.
IRF7204_Pch_20V5.3A_Vgs10V_60mΩ_ICtype.pdf
APM4435_Pch_30V8A_Vgs4.5V24mΩ_10V16mΩ.pdf
APM9435_Pch_3B0V4.6A_Vgs4.5V_80mΩ.pdf
IRF7606_Pch_30V3.6A-Vgs4.5V1.2A_Vgs10V2.4A_90mΩ.pdf
The below are the n mosfet to suit your need.
NTMS7N03R2_Nch_30V7A_Vgs10V_23mΩ.pdf
APM9435_Pch_30V4.6A_Vgs4.5V_80mΩ.pdf
DMN3150L_Nch_30v3.8A_72mΩ.pdf
You can also go to the online store to choose and buy.
Wendy
Joined Mar 24, 2008
23,797
With a little mod, you could have a joule theif approach, and it will not run out of battery power. If you are interested I will draw a schematic, but I have to be asked.
Aurion45
Joined Aug 7, 2011
64
With a little mod, you could have a joule thief approach, and it will not run out of battery power. If you are interested I will draw a schematic, but I have to be asked.
Hi Wendy,
The more the merrier, sound interesting, Yes please, draw a schematic???????????? 12 volts battery
Andrew
ericgibbs
Joined Jan 29, 2010
21,485
hi A45.
As the 555 is now running on 12V, it will be necessary to modify the P1 and LDR , light/dark sensing.
What is the resistance of the LDR when and dark and light.?
E
Aurion45
Joined Aug 7, 2011
64
Got No idea, as I did not noticed the value missing in the schematic, can we use 10M LDR? also will it work for the existing circuit above "ScottWang" made?
