Change Over Circuit
chiranjeeva
Joined Oct 19, 2019
2
I want to design a circuit in, which when the normal power supply is cut off device switches to battery power automatically what are the possible ways to do that
Ian0
Joined Aug 7, 2020
13,278
Two schottky diodes, one in series with each supply. BUT the load would be supplied from the battery whenever the battery voltage was higher than the normal supply, even if the supply had not failed.
